Using Post settings like featured posts and Post Categories
Home › Forums › Calendar Products › Events Calendar PRO › Using Post settings like featured posts and Post Categories
  • This topic has 1 reply, 2 voices, and was last updated 8 years ago by onedsign.
  • #1611642
    onedsign
    Hallo,
    As you discribed in the Topic “Event Categories as Post Categories” I could display and select Post Categories on my event editor. I selected a event as the category “Projekte” which should show up on my frontpage. Unfortunately I doesn’t. How could it work?
    The other function I need is, to show the event in my featured post slider. How could I handle this? Currently I need to build a seperated post, which I would like to prevent.
    I’m using the theme bima.
    Thank you very much,
    Holger Brandt
    ONEDSIGN – WEBMASTER
    #1612855
    Hi Holger,
    Thanks for reaching out!
    How far did you get in implementing that snippet? Do you get any error messages?
    Once you have that snippet in your functions.php file and edit an event, you will see to Category meta boxes on the right side: https://dl.dropbox.com/s/uoiaheymd31mezt/shot_180904_131927.jpg
    They might not be right below each other. Do you see them both?
    this essentially looks like a custom development task and so is outside of our stated scope of support.
    With that being said, we’d love to help point you in the right direction.
    If you’d prefer not to tackle this customization on your own, we may be able to assist you further. We do need to prioritize support requests from other customers at this time but I’ll certainly flag this with the team and – although we can’t make any promises – if we have time and space to come back and help, we’ll be happy to do so.  Please let us know if you’d like to go this route so that you can be added to this queue.
    If you urgently need help with this, however, you may instead wish to consider working with a suitably skilled developer or designer who can offer the additional level of support you require.
    Thanks and cheers,
  • The topic ‘Using Post settings like featured posts and Post Categories’ is closed to new replies.
