Home › Forums › Calendar Products › Events Calendar PRO › Sorting Date For Posts Does Not Work When Events Calendar Pro 3.11 Is Activated
- This topic has 11 replies, 6 voices, and was last updated 11 years, 2 months ago by
Brian.
July 23, 2015 at 2:21 am #989256
Terence
ParticipantTry
http://localhost:8080/core/wp-admin/edit.php?orderby=date&order=asc
http://localhost:8080/core/wp-admin/edit.php?orderby=date&order=descIt will not sort, but by deactivating Events Calendar Pro 3.11, it works fine. Events Calendar Pro 3.10 also works fine.
July 23, 2015 at 6:03 am #989282Clara Morris
ParticipantI am having the exact same issue. Need to downgrade today to last version. Seems like a significant bug to me…
July 23, 2015 at 7:48 am #989369anteater
ParticipantAlso have problem with Post sort in admin with 3.11 Pro activated. Obvious Bug that needs attention. Please advise when fix will be available
Scott
http://www.coinweek.comJuly 23, 2015 at 7:50 am #989371accesswinnipeg
Participantsame problem here! can not sort any of posts making wordpress a pain right now!
July 23, 2015 at 9:10 am #989451Brian
MemberHi,
Sorry for the issues on this.
I can help troubleshoot this.
First, I can certainly help everyone here, but we can help you better if you create your own topic in the forum, where we can interact with you one on one giving you our full attention.
Having said that, I and two our support team members attempted to recreate the issue and could not. So it is not clear where this is coming from right away.
I personally tried on 3 different sites without issue.
Terence, To help narrow down the cause of this can you please post your system info following this guide in a private reply:
Also, if you change browsers that you have not logged into the site before or clear you cache does it change anything?
Let me know and we can go from here.
July 23, 2015 at 6:54 pm #989754Terence
July 24, 2015 at 12:12 am #989773brightestspark
ParticipantHello – there we have the same issue – the display order of our WooCommerce orders is out of whack with Event Calendar Pro 3.11 activated.
Default display is by order number (newest first). With ECP 3.11 active, it changes default display to in order of Status (A-Z from Cancelled to Refunded etc), then by order number oldest first. And you can’t change the order by clicking on the titles.
Tested in Firefox, Safari and Chrome (I thought Chrome’s buggy update yesterday was causing it but no).
Will post a separate private reply with system info.
July 24, 2015 at 12:15 am #989774brightestspark
ParticipantSorry – will create a separate topic.
July 24, 2015 at 9:16 am #989978Brian
MemberHello,
We are still not why this happens on certain installs, but we have a fix that helped in one case so far.
Please use this link to download this plugin and upload and active to your site:
Let us know if that fixes the issue for you.
July 30, 2015 at 9:17 pm #992020Terence
ParticipantIt works with the .1 fix =)
July 30, 2015 at 9:40 pm #992021Clara Morris
ParticipantThanks so much for everyone’s help with this one and the speedy turnaround with the fix. I’ll try tomorrow.
July 31, 2015 at 7:51 am #992121Brian
MemberHi Mike,
The fix is now included in the 3.11.1 and 3.11.2 release so updating to those versions should fix the issue.
If you still have an issue please create a new thread on the forum as would seem to be something new causing it.
Since we have released a fix for this issue I am going to close this ticket, but if you need anything else related to this topic or another please post a new topic on the forum and we can help you out.
- The topic ‘Sorting Date For Posts Does Not Work When Events Calendar Pro 3.11 Is Activated’ is closed to new replies.
