Home › Forums › Calendar Products › Events Calendar PRO › Events Calendar PRO breaks display order for posts
- This topic has 20 replies, 2 voices, and was last updated 8 years, 5 months ago by
Meredith.
March 16, 2018 at 5:31 am #1481072
Victor
MemberHi Aaron!
Thanks for following up.
I’ve just checked the report for this issue and it seems one of our developers already proposed a fix for it, but unfortunately it won’t be available in the next maintenance release, due to some other priorities involved.
Rest assured we will let you know when the fix is available for you to try.
VictorApril 10, 2018 at 12:22 pm #1503407Meredith
ParticipantHi Victor,
I wanted to check in again. It’s been almost 2 months since I first reported this issue! Any update on when that proposed fixed might be implemented? And/or is there a code snippet I can add to the current version of the plugin to fix the problem in the meantime?
Aaron.April 11, 2018 at 7:27 am #1504271Victor
MemberThis reply is private.
April 11, 2018 at 2:26 pm #1504838Meredith
ParticipantVictor,
I tried replacing the file and it fixed the problem (I looked at the code in a diff as well, and the change makes logical sense, I’m happy to say). Thank you for providing us with this!
Will this fix be released in the next release of Events Calendar PRO? Or will the next release overwrite this change?
Aaron.April 12, 2018 at 4:36 am #1505289Victor
MemberHi Aaron!
Thanks for your confirmation. Glad it worked out for you! 🙂
It seems most likely the fix will included in our next release of Events Calendar PRO, but I can’t really commit to it. The fix still has to undergo a series of steps (QA, smoketest) to make sure it works well in conjunction with other fixes.
Rest assured we’ll notify you in here once the fix is released. You can also check the changelog before updating the plugin to see if the fix is present.
VictorMay 9, 2018 at 5:37 pm #1526802Victor
MemberHi Aaron!
Just wanted to share with you that a new release of our plugins is out, including a fix for this issue 🙂
Find out more about this release → https://theeventscalendar.com/maintenance-release-for-the-week-of-6-may-2018/
We apologize for the delay and appreciate your patience while we worked on this.
Please update the plugins and let us know if the fix works for your site.
VictorMay 31, 2018 at 9:35 am #1543062Support Droid
- The topic ‘Events Calendar PRO breaks display order for posts’ is closed to new replies.
