Home › Forums › Ticket Products › Event Tickets Plus › RSVP multiple confirmation clicks code snippet causes problem for required field
- This topic has 5 replies, 5 voices, and was last updated 8 years, 4 months ago by
Cliff.
May 15, 2018 at 6:38 am #1530675
ParticipantWe also had problems with multiple confirmations for RSVPs caused by double-clicking or multiple clicking before the form starts the submission process to the server. This is reported before here:
Cliff presented a code snippet to solve this problem in that thread. We also use that code snippet, but found that it causes problems when required fields are present and the user does not enter values (text) or select any value (for radiobuttons and checkboxes). In this case the form is not submitted, an error message is shown to the user, but the button’s click event (added by the code snippet) is also in place preventing any further submissions.
We solved this and suggest that you update your code snippet like this:
/** * Disable just the Submit button of the Event Tickets form after initial click to protect against sending data multiple times * From: gist.github.com/cliffordp/8bceb54b440fbe9de1d42df6f231cc7a * By Matt B. * Updated 2017-01-13 for latest versions of ET/ET+ * Updated 2018-05-15 by AndLen Re-enable button after 2s delay to enable it after an error message. **/ function tribe_snippet_prevent_multi_click_on_submit() { wp_enqueue_script( 'jquery' ); ?> <script> jQuery( function( $ ) { var $button = $( '.tribe-events-tickets-rsvp button[name="tickets_process"]' ); $button.closest( 'form' ).on( 'submit', function( e ) { $button.on( 'click', function() { return false; } ); // AndLen: Remove click handler (preventing further submissions) with 2 second delay after first click. setTimeout(function(){$button.unbind('click');}, 2000); } ); }); </script> <?php } add_action( 'event_tickets_rsvp_before_confirmation_fields', 'tribe_snippet_prevent_multi_click_on_submit' );The code adds a click handler to the submit button when the form is about to be submitted, preventing any more submissions when the button is clicked. Our addition removes this click handle after a 2 second delay to re-enable the button to allow submissions.
We have tested this and it now functions correctly also after error messages. The specified delay, 2000 milliseconds in this case, may be adjusted. We found this value to be good enough for our site.
May 15, 2018 at 6:44 am #1530679Andras
ParticipantSome characters in the code snippet are not presented correctly, but I hope the solution is clear enough.
May 15, 2018 at 7:51 pm #1531350Victor
MemberHi Andras!
Thanks so much for taking your time to share this so others can benefit from it.
I have tweaked the code in your reply so that it shows correctly. I will also make sure to pass this along to Cliff so he can check it out and update the gist.
Is there anything else I can help you with? Let me know about it.
VictorJune 6, 2018 at 9:35 am #1547612Support Droid
The Events Calendar Support TeamJune 13, 2018 at 3:05 pm #1552781Cliff
MemberAndras, thanks so much for sharing your alterations and sorry for the delay getting back to you.
I took yours as inspiration and updated https://gist.github.com/cliffordp/8bceb54b440fbe9de1d42df6f231cc7a to work with all our ticket types.
Please try it out and create a follow-up ticket if there’s anything wrong with it.
- The topic ‘RSVP multiple confirmation clicks code snippet causes problem for required field’ is closed to new replies.
