Problems With Roles Other Than Administrator After Pro2.0.9 Upgrade
Home › Forums › Calendar Products › Events Calendar PRO › Problems With Roles Other Than Administrator After Pro2.0.9 Upgrade
  • #26001
    Mike
    After upgrading both The Events Calendar free version and the Pro version to 2.0.9 inputting events is no longer possible except for Administrators. Prior to upgrading to 2.0.9 we had all User Roles set up for full privileges regarding events using Members plugin and all roles could add events.
    After 2.0.9 upgrade all user roles except Administrators have these problems;
    1.0 Events page renders only “Filters & Columns” title with drop down “add a filter” menu below.
    2.0 Add New Event page renders Event Title, Description, and Event Date and Time but the date picker etc. do not function. Last line seen is “Use Saved Menu” which is beginning of section header Event Location Details.
    Again, the events plugin behaves for Administrators, it all other user roles that have the problem.
    We also use the Community Events add on here but I have deactivated it.
    Any advice on how to fix would be much appreciated!
    #26011
    Jonah
    Hi Mike,
    Can you send me a screenshot or provide me wp admin access so I can see for myself, the permissions set for the users in question? You can email access to pro [at] tri [dot] be
    Also, have you tried deactivating all other plugins except for ours?
    Jonah
    #26030
    Jonah
    Hi Mike,
    Thanks for providing me access. I think I know what’s going on here. Traditionally a Contributor can create new posts (not publish) and be able to read all posts including events. I noticed when I logged in as a Contributor in my local install and looked at my events list at first I only saw the posts that user had created but then I could click on the Published link above the list and see all the events. Did you try clicking on any of these links: http://cl.ly/image/0N2Y0B362Q3H
    Does that change anything?
    – Jonah
    #26032
    Jonah
    Mike, have you tried deactivating all other plugins and/or switching to the Twenty Eleven theme to see if this could be a conflict with a plugin or some of your theme code?
    – Jonah
  • The topic ‘Problems With Roles Other Than Administrator After Pro2.0.9 Upgrade’ is closed to new replies.
