Home › Forums › Calendar Products › Community Events › Problem with breadcrumbs – undefined index notices
- This topic has 4 replies, 2 voices, and was last updated 12 years, 1 month ago by
Brian.
September 2, 2014 at 10:41 am #717451
Galen
ParticipantJust installed Community events and it appears to be working great. On my page that contains the add event form My theme is throwing a bunch of warnings – looks like my theme is having a problem with the taxonomy for the add page.
Notice: Undefined index: Hpost_wp_router_page_template_no_anchor in /home/artsmon/public_html/blog/wp-content/themes/parallelus-vellum/extensions/breadcrumb/breadcrumb_navxt_class.php on line 577Notice: Undefined index: bpost_wp_router_page_taxonomy_display in /home/artsmon/public_html/blog/wp-content/themes/parallelus-vellum/extensions/breadcrumb/breadcrumb_navxt_class.php on line 432
Notice: Undefined index: apost_wp_router_page_root in /home/artsmon/public_html/blog/wp-content/themes/parallelus-vellum/extensions/breadcrumb/breadcrumb_navxt_class.php on line 861
Notice: Undefined index: bpost_wp_router_page_archive_display in /home/artsmon/public_html/blog/wp-content/themes/parallelus-vellum/extensions/breadcrumb/breadcrumb_navxt_class.php on line 917
Notice: Undefined index: Hpost_wp_router_page_template_no_anchor in /home/artsmon/public_html/blog/wp-content/themes/parallelus-vellum/extensions/breadcrumb/breadcrumb_navxt_class.php on line 942
Notice: Undefined index: Hpost_wp_router_page_template in /home/artsmon/public_html/blog/wp-content/themes/parallelus-vellum/extensions/breadcrumb/breadcrumb_navxt_class.php on line 951
Arts Monongahela > > Submit an EventI can turn off breadcrumbs and the notices go away. Not a huge issue but thought i would post here if there is a simple fix.
September 3, 2014 at 7:48 am #719386Brian
MemberHi,
Sorry for the troubles, not sure if there is a simple fix, but it is possible.
If you can find the function, which is calling the breadcrumbs and can remove it using an action. You could use the coding below to target the Community Pages to disable it on just those pages.
* Run on Community Events Pages Only
* @3.7
add_action( 'wp_head', 'evensts_run_on_community_pages' );
function evensts_run_on_community_pages( $query ) {
if ( tribe_is_community_my_events_page() || tribe_is_community_edit_event_page() ) {
/*add coding here */
}Another option is to bring it to the attention of the developer to run isset checks to prevent the errors from showing.
Let me know if that helps.
September 3, 2014 at 12:40 pm #720023Galen
ParticipantThanks I tried that and it just seemed to nuke the breadcrumbs off of every page
I tried using an if (is_page()) but couldn’t get it to work with the page id, slug or title.
This is the code in the header file that calls the breadcrumbs
$showBreadcrumbs = get_options_data(‘options-page’, ‘show-breadcrumbs’);
$showBreadcrumbs = ( !empty( $header[‘header-breadcrumbs’] ) ) ? $header[‘header-breadcrumbs’] : $showBreadcrumbs;I will contact the theme dev and see what they have to say.
September 4, 2014 at 10:47 am #722252Galen
ParticipantI had WP_DEBUG set to true while I was fixing another issue – changing it back to false stoped the notices from displaying and the breadcrumbs now work normally.
September 4, 2014 at 10:54 am #722259Brian
MemberI am glad to see you were able to fix the issue.
Since the issue is resolved I am going to go ahead and close this ticket. If you have a similar issue or another in the future, please do not hesitate to create a new ticket.
- The topic ‘Problem with breadcrumbs – undefined index notices’ is closed to new replies.
