Problem when using maintenance plugin
Home › Forums › Calendar Products › Events Calendar PRO › Problem when using maintenance plugin
  • #1208729
    Matt
    I have tried to use a maintenance plugin on our site which works fine. All the other pages are fine once I have signed into the front end of the maintenance plugin but as soon as I access the Events page the maintenance plugin blocks the page and I have to sign in again. This means I cannot display the Events page for testing whilst in maintenance mode.
    Have you come across this problem before? Any ideas?
    #1209190
    Nico
    Hi there Matt,
    Thanks for getting in touch with us, and sorry to hear about this problem 🙁
    I just tested the plugin (Maintenance version 3.2) with default theme Tweenty Seventeen and The Events Calendar. Everything worked as expected, but I did see a JavaScript error in the browser console from a js file from the theme.
    Not sure how the plugin works, or what are your site needs. Depending on these, you might want to tweak the plugin options a bit (maybe disable the front-end login form), reach out to them to see if they are aware of the problem or just use a different plugin to achieve the same.
    Also, while I couldn’t find any other customers reporting problems with the plugin I could find some cases of other customers using it without trouble.
    Please let me know about it,
    Nico
    #1217429
  • The topic ‘Problem when using maintenance plugin’ is closed to new replies.
