Home › Forums › Calendar Products › Events Calendar PRO › Problem When using List View for Events
- This topic has 9 replies, 4 voices, and was last updated 11 years, 3 months ago by
Support Droid.
August 16, 2013 at 2:47 pm #60839
Eric
ParticipantI have noticing an error in the list view of your calendar. It seems to repeats months and jumble up events. Can you tell me whats going on?
August 20, 2013 at 10:51 am #61798Rob
MemberHey Eric! Thanks for the note here, and please accept my apologies for the delayed reply. I want to do what I can to get this sorted for you in as timely a fashion as possible.
It appears as though you’ve fixed this problem? When I view list view at the link you provided, it appears to be showing events in the proper order going forward: http://d.pr/i/mtzv. Let me know if I’m misunderstood here though.
August 20, 2013 at 12:01 pm #61892Eric
ParticipantThat is just page one. Please go to the next page. That is when it fouls up.
August 26, 2013 at 1:04 pm #62866Barry
MemberHi Eric,
I can see what I think is the issue you are describing if I view past events – but cannot replicate this.
Can you confirm if you tried deactivating all other plugins except for those by Modern Tribe and switching to a default, unmodified theme? If so did that help to isolate the problem?
August 26, 2013 at 7:31 pm #62977Eric
ParticipantWell I am sorry. It took too long to get a response, so I just set the posting limit to 50 per page to avoid the issue. I have not disabled plugins to see what the cause is. However, what you see when viewing the previous posts is exactly what I am talking about. You see 2013 events and then you see december 2012 and then you see 2013 events again. It does the same when viewing “next events” too. Any other ideas? Any known problematic plugins? Everything worked just fine until the update. Same plugins before and after.
August 26, 2013 at 7:35 pm #62979Barry
MemberI haven’t heard of this particular issue before – so the best way really would be to run through those troubleshooting steps (perhaps assessing the impact on the previous events page if you’ve set posts-per-page to 50).
Perhaps you could even test locally or create a new installation and add the various components of your production site one by one, to avoid disruption – would that work here?
August 26, 2013 at 8:06 pm #62982Eric
ParticipantOk. The problem is the plugin called Post Types Order Version 1.6.2 | By Nsp Code | Visit plugin site
August 26, 2013 at 8:14 pm #62983Eric
Participantdont need it, unimportant so I just deactivated it. I think that was like a standard installed plugin or something cause I do not think I have ever used it. Thanks for help. Now you all can reproduce to see how to work with it, or get them to fix their code to work with your plugin.
Thanks again and by the way, love the plugin!!
August 27, 2013 at 5:10 am #63011Barry
MemberGreat! And thanks for reporting back with those details, we’ll add that to our issue tracker 🙂
July 7, 2015 at 6:27 am #980360Support Droid
- The topic ‘Problem When using List View for Events’ is closed to new replies.
