Home › Forums › Calendar Products › Events Calendar PRO › Problem using import csv – Venues and Events
- This topic has 4 replies, 2 voices, and was last updated 10 years, 6 months ago by
Brian.
April 24, 2016 at 8:24 am #1106414
Nicolas
ParticipantI have simple list of 54 venues i am trying to import and no matter what we try only 1 venue is imported.
The response is:
Import complete!
Inserted: 1
Updated: 53
Skipped: 0We have made sure that the csv is the in the right format. The same problem was addressed here: https://theeventscalendar.com/support/forums/topic/problem-using-import-csv-venues-and-events/#post-107030 but nobody deemed important to share what solved the problem (which is crazy, considering that many users manage to find answers to their problems by browsing forums).
Once Venues added, I will upload the Events export. Hopefully, this will work too…
Could you help me address this, please?
ThxApril 24, 2016 at 8:54 am #1106422Nicolas
ParticipantI noticed that the issue described in my previous thread is caused by the fact that all my venues are imported under a same post ID (1231), instead of a different post ID per each venue/entry. However, the import feature does not seem to include any “ID” field, which seems to cause the above mentioned problem.
April 24, 2016 at 3:17 pm #1106455Brian
MemberHi,
Sorry for the issues here.
This is a bug due to a change in WordPress 4.5 to the post_search filter.
We have a fix coming in the Events Calendar 4.1.3 later this week.
However, to fix right away please change the contents of this file:
Please note you must correctly change the entire contents of the file as any mistake could cause the website to go down.
the-events-calendar/src/Tribe/Importer/File_Importer.php
With this:
That should resolve the issue for you.
Let us know how that works out.
Cheers
April 25, 2016 at 9:35 am #1106696Nicolas
ParticipantThanks Brian, this worked perfectly; I managed to import the list of Venues (using the WP “import” feature, as Tribe Event’s import feature missed some import fields), and all venues have been create properly.
I’m gonna report another issue in a new thread, as when I imported my list of events (after venues were imported), it created duplicates for each events. Url appeared as /event/my-special-event/all/ and /event/my-special-event-2/all/
April 25, 2016 at 11:52 am #1106754Brian
MemberSounds good.
I am going to close this ticket to new replies, but the issue is still open and we will update this ticket once we release a fix later this week.
If you have any new questions or issues please create a new ticket and reference this one.
- The topic ‘Problem using import csv – Venues and Events’ is closed to new replies.
