Possible to use info from regular posts for Event Calendar PRO
Home › Forums › Calendar Products › Events Calendar PRO › Possible to use info from regular posts for Event Calendar PRO
  • #32651
    Rachael
    Prior to using this plugin we were using a theme widget for showing events on our homepage. We have already inputted all of our events for the season as regular posts. Is it possible to somehow transfer these previously entered posts to use with Events Calendar PRO widget or must we manually reenter all of this info? Thanks for your help
    #32693
    Jonah
    Hi Rachael,
    The only thing you can do at this point is use a plugin like this http://wordpress.org/extend/plugins/convert-post-types/ to convert the post type of the regular posts to Events. It won’t migrate over the date/time info so you’ll need to figure out some other way to do that or do it manually.
    I hope that helps, let me know if you have any other questions.
    Jonah
    #32723
    Rachael
    Jonah,
    Thanks for this suggestion. I’ll give it a try!
    #32729
    Jonah
    You’re welcome Rachael!
    #978621
  • The topic ‘Possible to use info from regular posts for Event Calendar PRO’ is closed to new replies.
