Not choosingVenue and Organiser using Events Calendar Pro 2.0 with Gravity Forms
Home › Forums › Calendar Products › Events Calendar PRO › Not choosingVenue and Organiser using Events Calendar Pro 2.0 with Gravity Forms
  • #12536
    Aaron
    Hi, I’m using Gravity forms to add events and after I post the event I get use new organiser and use new venue when I open the event but neither is being chosen from the one that I just added. I go through the list and it has been added to the list but it doesn’t choose it.
    How do I make it select the one that is being created from the Gravity forms?
    thank you.
    #12549
    Rob
    Hey Aaron. Have you checked out our forum on this, where users were exchanging suggestions on how to make it functional? It’s right here: https://theeventscalendar.com/support/forums/topic/integration-with-gravity-forms/. We also published some suggestions on our end: https://theeventscalendar.com/event-submissions-using-gravity-forms-in-2-0/.
    While we can’t provide direct support on that hack (though you may be able to get some suggestions by checking with Tim, who wrote the GF integration aspect initially), I will note that our official equivalent of this – the Community Events add-on – will be out in early 2012 and should have what you’re looking for in it.
    Sorry I can’t offer more here. Let me know if you have any other questions on this.
    #12643
    Aaron
    Hi Rob, I just tried it again and I just can’t seem to get it right.
    The venue and organiser still don’t get saved.
    do i need to do anything special for them other than add this to the functions.php: https://theeventscalendar.com/event-submissions-using-gravity-forms-in-2-0/
    time and date gets saved and the event as well. but the venue and organiser don’t seem to work for me.
    these are the fields i’m using: _VenueAddress _VenueCity _VenueZip
    these are the fields i’m currently not using: _EventVenue, _EventVenueID, _VenueVenue, _VenueCountry, _VenueAddress, _VenueCity, _VenueStateProvince, _VenueZip, _VenuePhone
    is it because there’s mandatory fields for venue? if so, what are they? eventvenue? venuevenue? etc.
    s the country mandatory if it’s already set to default for a country?
    am i meant to set the venueid or that gets set automatically as it’s added and that creates the database relationship?
    organiser fields used: _OrganizerOrganizer, _OrganizerPhone, _OrganizerEmail
    organiser fields not used: _EventOrganizerID, _OrganizerWebsite, _OrganizerPhone
    same for organiser.?
    thanks. aaron.
    #12758
    Rob
    Hey Aaron. I’ll see if I can get one of our advanced devs to offer up their insights on this, sometime this week.
  • The topic ‘Not choosingVenue and Organiser using Events Calendar Pro 2.0 with Gravity Forms’ is closed to new replies.
