Home › Forums › Ticket Products › Event Tickets Plus › Export/Import tickets and their products between Dev/Test/Live
- This topic has 5 replies, 2 voices, and was last updated 9 years, 5 months ago by
Rob.
April 26, 2017 at 12:40 pm #1274872
Rob
ParticipantWe have a separate site set up for each of dev, test, and live versions of our site. I have someone updating just event tickets and their corresponding WooCommerce products on Dev, which we’ll then want to put on Test and then Live. Is there an export/import way to do this so that we don’t have to copy/paste event info between the environments? I know we could just do a whole database copy on the back-end but we have other content staging things going on in parallel and that would mess those up.
April 27, 2017 at 8:11 pm #1275558Cliff
MemberHi, Rob.
It sounds like you’re wanting the actual Event + Organizer + Venue posts, not the Event Settings, right?
If so, you can use WordPress’ own import/export functionality at wp-admin > Tools > Import or Export.
Please let me know how this goes for you.
April 29, 2017 at 1:47 pm #1276402Rob
ParticipantWould that also include the WooCommerce products that were created with the event?
April 29, 2017 at 8:10 pm #1276438Cliff
MemberYou should have all the same plugins active on Site B as you do on Site A, otherwise the import process may not import the registered post types.
For example, if Site A has The Events Calendar and WooCommerce active and you generate a WordPress export file, it’ll export Events, Organizers, Venues, and Products custom post type posts.
Then, if Site B has The Events Calendar (but not WooCommerce) active, and you import Site A’s export file, Site B will likely import Events, Organizers, and Venues, but not Products.
Obviously, then, you should have WooCommerce active on Site B if it’s active on Site A.
There are also other data migration tools available. For example, some people use the Duplicator plugin (third-party, not guaranteed or supported by us) to just copy the entirety of Site A to become Site B. Then, once Site B is a clone of Site A, make the staging/development edits you need to make as if it were Site A.
Alternatives include Backup Buddy, ManageWP’s backup/clone service, and quite a few others.
I hope this clarifies things for you. Please let me know how this goes for you.
May 21, 2017 at 9:35 am #1286866Support Droid
- The topic ‘Export/Import tickets and their products between Dev/Test/Live’ is closed to new replies.
