events-calendar-pro does not zip with control right click
Home › Forums › Calendar Products › Events Calendar PRO › events-calendar-pro does not zip with control right click
  • #1551174
    barry wolfe
    “To make it a .zip, right click the folder and select Compress. Then you will have a .zip file again.” does not work.
    On my Mac I get 4 options in the drop down box: OPEN, SHOW IN FINDER, COPY ADDRESS, REMOVE FROM LIST.
    If I double click the downloaded folder, I get several text documents and 3 folders; events-calendar-pro.php, lang folder, license.txt, readme.txt, src folder, vendor folder. If I control>right click these they open but I don’t know what to do with them, have no way to download them upload them offload them or install them?
    I don’t know what FTP is. This plugin should not be so difficult to download and install. Just sending me links to generic documentation is not helping me solve this problem. I sent all my website and computer info in a previous email. Make this work!
    HELP!
    #1552050
    Cliff
    Hi, Barry. Sorry you’re having trouble getting started.
    When you download the plugin .zip fromĀ https://theeventscalendar.com/my-account/downloads/, don’t unzip it on your Mac. Instead, go to your site’s wp-admin > Plugins > Add New > Upload > and drag the .zip from Finder to there.
    Once installed, you need to Activate it.
    You can read in more detail atĀ https://codex.wordpress.org/Managing_Plugins#Installing_Plugins
    Please let me know how this goes for you.
    #1567680
  • The topic ‘events-calendar-pro does not zip with control right click’ is closed to new replies.
