Event Tickets Pro products not compatible with Woocommerce shortcodes ?
Home › Forums › Ticket Products › Event Tickets Plus › Event Tickets Pro products not compatible with Woocommerce shortcodes ?
  • This topic has 3 replies, 4 voices, and was last updated 10 years ago by Jens Kirk.
  • #1159656
    Jens Kirk
    Hello!
    I am using woocommerce shortcodes to display my events on my pages.
    When I use [add_to_cart id=”xxx”], the result behaves as expected.
    When I use [product id=”xxx”] or [product sku=”xxx”] I get a blank result for any Event Ticket pro created products. For any regular products, it works fine.
    My question is: why do Event Ticket Pro products behave differently than regular products and is this a bug you are aware of?
    If it is a bug, can you release a fix, so we can use woocommerce shortcodes as expected.
    Thanks for a great plugin!
    Cliff
    Hi Jens.
    I tried a page with this content: https://cl.ly/3w2R2A3r3Y37
    Which resulted in this output: https://cl.ly/2x2l3r1m2r3X
    Therefore, I can say the add_to_cart shortcode seems to work.
    However, even if all these shortcodes worked, they would be bypassing the Event Tickets Plus system. This could very likely mess up remaining stock counts, assigning the user to the proper ticket to the proper event, and possibly other side effects.
    Event Tickets Plus (ET+) is currently only designed to have tickets be purchased from single Event pages.
    I believe you’re requesting the same thing as one of our existing feature requests: https://tribe.uservoice.com/forums/195723-feature-ideas/suggestions/15651939-event-tickets-plus-woocommerce-i-would-like-to-be
    Please do add your vote there.
    This allows us to gauge interest in this particular feature request, which helps us prioritize our development efforts.
    Thank you.
    #1169281
  • The topic ‘Event Tickets Pro products not compatible with Woocommerce shortcodes ?’ is closed to new replies.
