Howdy Laughmasters!
Thanks for taking the time to report a suspected inaccuracy!
This link: https://theeventscalendar.com/knowledgebase/themers-guide/
Shows the incorrect path: the-events-calendar/src/views/modules/meta/details.php
When it’s really: the-events-calendar/src/views/pro/modules/meta/details.php
I’m not quite sure what’s inaccuratehere. The file you suggested does not exist on my copy of The Events Calendar, I don’t even have a /pro/ folder inside of /the-events-calendar/src/views/ . However I am wondering if perhaps you meant to refer to the “additional-fields.php” file instead. In which case it can be found here (as you know):
/events-calendar-pro/src/views/pro/modules/meta/additional-fields.php
Thus you would want to put it in the following location in your theme:
/wp-content/themes/[YOURTHEMEFOLDER]/tribe-events/pro/modules/meta/additional-fields.php
It sound like our documentation was not clear enough on where to put the additional-fields.php file. Thanks for sharing that feedback. I whole heartedly agree with it, it’s article we plan to rewrite and simplify.
Did that answer your question?
– Brook
